DSD+ New Install Crashes
LubeckTech
Parkersburg, WV
I have successfully install DSD+ many times on Windows PCs but an having a problem with a new install.
The Computer is a Getac with a Core i7 2ghz 4gb ram and windows 10.
The program starts and the last line on the screen says "audio input device open failed" then it shuts down.
I have VB Audible Cable installed and working and have even started the program with a batch file that specified that input at startup.
Anyone have an idea what is shutting down DSD+??
cg
Connecticut
What Version? Fast Lane or the old free version?
If this is a new machine, did you run Zadig?
If Fast Lane, are you up to date with the exe files and the dlls as per the last update instructions?
chris
LubeckTech
Parkersburg, WV
Problem happens however I start the program - with or without the batch file.
I am a fastlane member but am just trying to get the original 1.01 program (with decompressed DLLs) to run before trying updates - will try applying updates and see what happens.
a417
Can you run the same install correctly with FMPx?
