DSD not working with windows 10
ve3ext
tried several things,no luck.
Presently usingDSD1.074 .
All was working perfectly with windows 8.1
Help please and Thanks
Jerry
ve3ext
simply not decoding!
What version of dad are you using?
Do I need to do anything different., e.g.open a port?
Windows 8.1 worked beautifully.
Tnx for any tips
Jerry
shiawase9983
Mine worked with Virtual Coax.
Try and see if the settings are correct for input and output. Also, try listening to the undecoded signal and see if it is good.
ve3ext
DSD not working windows 10
Now appears to be working., had to turn on the mic in sound card!
Tnx
Jerry
Bart911
Eagle Pass, Texas
Hello, I am interested in setting up a DSD software for the first time. Any good starter programs there for a novice? I am operating a BCD996P2 and my Op system is Windows 10. 73
moonbounce
Same problem, DSD 1.74 with FMP works fine, DSD 1.51 doesn't work. I will get a little bit of scroll but no sound, message says unrecoverable NID, this is with a tapped scanner only. With SDR Sharp and DSD 1.51 they work perfectly together, there seems to be something I am missing to run DSD from the discriminator tap.
