Im using DSD Plus fastlane to listen to both analogue and digital signals but having a problem with choppy analogue audio.
I have it set to "raw source audio monitoring set to 1 (monitor if no sync or signal present).
This will pass both analogue and digital signals but im only having the problem with analogue cutting out.
I feed from SDR Uno via vb audio with signals of varying strengths and appear to have the same issue on all strengths.
If I bypass DSD plus and play directly to my speakers, there is no cutting out (it also doesnt sound as muffled) so know the actual feed from Uno is ok.
I have squelch off and no filtering enabled in uno and the "sys" is very low and not effecting signals" .
Is there a setting in DSD where i can set a monitoring threshold to control this ? (there is a "monitoring threshold" option, which makes no difference).
Im aware it could also be vb audio, but i wanted to check im there was a DSD option first.
Also, is there a reason DSD is muffled on all audio and is there something that can be done ?
many thanks
many thanks
