Clear4Code7
- Joined
- Mar 2, 2021
- Messages
- 25
I've been using DSD Plus Fastlane for a bit over a year to monitor a NEXEDGE 4800 site and have always had issues missing traffic on the voice channels since the beginning. I always have it set to hold on a specific talk group, yet I'm missing over 80% the voice transmissions.
When traffic is missed, the control channel shows a talk group assignment and radio ID, but the FMP24 window for the voice SDR sits at idle. It doesn't even attempt to follow the voice channel assignment. I'm using the following setup:
- Dedicated SDR for control channel and dedicated SDR for voice channel
- I've tried swapping SDRs between control and voice to rule out antenna or other SDR issues. Behavior is the same regardless of which SDR/antenna is assigned the control channel vs voice channels
- When voice traffic is followed (roughly 20% of the time), the FMP24 VC output window tunes without errors in the bit stream. Voice audio is clear without drop-out or distortion from missed frames.
- Signal strength on both control channel and voice channels is strong (both using gain of 49.6), but not excessive. Current bandwidth setting is 4 on both SDRs.
- DSD+ and FMP24 Settings:
- FMP24 window indicates both SDRs are Rafael Micro R820T
- Using direct link between FMP24 and DSD+ (on both VC and CC SDRs)
- DSD configured to only decode NXDN4800. All other protocols disabled
- Noise filter and shaping filter enabled
- DSD output windows show no errors in either VC or CC
- Running Windows 10 Home Edition, Intel i6700 processor with 16GB ram.
- Task manager never shows FMP24 or DSDPlus exceeding 1% of CPU or consuming more than 24MB of memory
- Overall system CPU utilization sits around 6 to 7%, memory usage around 50%, and disk utilization 0 to 1%
- Using SSD for OS and user partitions, but DSD+ is run off magnetic disk. Windows Resource Monitor shows very low disk utilization on the DSD+ drive (usually 0.00 to 0.01 queue length)
