stillline1979
I have a uniden bearcta scanner with a discriminator output mod. It wokrs perfectly decoding audio with DSDplus in windows.
However when I try to use it with DSplus in Linux i get the error
Syncing voice output stream
An error occured while using the portaudio output stream
Error number: -9983
Error message: Stream is stopped
Below is the the output of the command dsd -a. Any help with this would be greatly appreciated. I really need this to work in ubunut as my windows machine is busy doing other things that actually pay the bills.
matthew@matthew-OptiPlex-745:~$ dsd -a
Digital Speech Decoder 1.7.0-dev (build:v1.6.0-86-g7ee04e5)
mbelib version 1.3.0
ALSA lib pcm.c:2266snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2266snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2266snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for 4294967295, skipping unlock
PortAudio version number = 1899
PortAudio version text = 'PortAudio V19-devel (built Aug 11 2015 07:04:31)'
Number of devices = 9
--------------------------------------- device #0
Name = HDA Intel: AD1983 Analog (hw:0,0)
Host API = ALSA
Max inputs = 2, Max outputs = 2
Default sample rate = 44100.00
--------------------------------------- device #1
Name = sysdefault
Host API = ALSA
Max inputs = 128, Max outputs = 128
Default sample rate = 48000.00
--------------------------------------- device #2
Name = front
Host API = ALSA
Max inputs = 0, Max outputs = 2
--------------------------------------- device #3
Name = surround40
Host API = ALSA
--------------------------------------- device #4
Name = surround51
Host API = ALSA
--------------------------------------- device #5
Name = surround71
Host API = ALSA
--------------------------------------- device #6
Name = pulse
Host API = ALSA
Max inputs = 32, Max outputs = 32
--------------------------------------- device #7
Name = dmix
Host API = ALSA
--------------------------------------- device #8
[ Default Input, Default Output ]
Name = default
Host API = ALSA
Error number: -9983
Host API = ALSA
Name = sysdefault
Host API = ALSA
Name = front
Host API = ALSA
Name = surround40
Host API = ALSA
Name = surround51
Host API = ALSA
Name = surround71
Host API = ALSA
Name = pulse
Host API = ALSA
Name = dmix
Host API = ALSA
Name = default
Host API = ALSA
