DSD
Trooper_Dean
Hello y'all!
Is it possible to connect TYT TH-9800 with DSD? I did so, with a 3.5mm cable but there is an issue... DSD+ receives the audio coming from the radio (visible on graph) but doesn't decode it. What is a thing?
cg
Connecticut
Unless you can get raw unfiltered audio from that plug then no, DSDPlus will not decode it.
chris
cg
Connecticut
Easy way: Spend $25 and get a basic SDR and use DSDPlus with the included FMP24.
Hard way: There is likely a place inside the radio where unfiltered audio is available and could be accessed with an audio cable soldered in place then run to the outside of the radio. Other than a better receiver hearing the signal, there isn't much to gain.
chris
merlin
DN32su
2 ways, >easy is use an SDR dongle.
>If you are technically adapt, you can tap directly off the discriminator output.(before filtering and de-emphasis.
That will take a small gain am to get the audio level useable.
