DSDFastlane, Event log with bottom in red....
IU0LFT
Italy
Hi , as seen on picture, the bottom info line on one Event Log is red, all the others are gray, any idea why?
Giuseppe
dave3825
rebmeM evitcA
Suffolk County NY
For the gray, what is your color scheme set to?
As far as red on the bottom of event window, its mentioned in another thread that it means "Isolated site (network failure) Switch to single site trunking at that site"
Red text in the siteloader window means it lack freqs.
cg
Connecticut
And that red bar may not reset when the site is back connected. You may have to click off the frequency and back again to see if it is back online with the network.
IU0LFT
Italy
Hi, color scheme is Normal Color Scheme,
Site it's a CAP-Max TIII 164.0125 MHz, I'll check if the other site on 164.2625 MHz will fail..
