Fastlane version of dsd was working great first time i run for dmr decode. But since last use the COMBINED CC/VC MONITER tab is greyed out and cant click on it. Passive; cc monitor; vc monitor tabs only highlighted not combined.?? Help Please.
Run the FMP24-CC.bat file to start FMP24.Thanks i tried using FMP24 after watching various how to but when the window opens to start decoding i get a No connect TCP error target machine not recognized.??
False.Computer refuses to connect to TCP ADDRESS .
You have the program set to load a particular system on startup (it is a menu option), and that system is incorrect. You need to push back, take a big deep breath and look at that site you are trying to set up. It is not a TCP ADDRESS error like you are insisting it is.Start up trunking site window states ERROR MESSAGE.
If DSD+ won't connect to FMP24, you have a software version mismatch. What versions of DSD+ and FMP24 are you running?Thanks for all suggestions. Have tried with no luck. Computer refuses to connect to TCP ADDRESS . Start up trunking site window states ERROR MESSAGE. Completely wiped version of dsd. With fresh install of fastlane still no success. Would have liked to get into radio but it's trying my patience.
I have the latest fastlane update of DSD+ but it did not include an updated FMP24. I get the mismatch error. How to get the latest FMP24 fastlane update?If DSD+ won't connect to FMP24, you have a software version mismatch. What versions of DSD+ and FMP24 are you running?
