DSDPlus DSDFL Data L/O
billy2047
📶 🕨 Ø T₁ ÆS Ⱬ ⬜ ᴴ L |→| 𝅘𝅥 💾 🛰️ 🔋
SYS REG RFSD
Hi all, does anyone know is there a way to force DSDFL to follow data channel grant? Right now my DSDFL automatically L/O all data channel grant and I have Data Calls set to High Priority under Control menu, which doesn't seem to work.
Thanks all!
Have you tried these settings, VOICE/DATA CALL FOLLOWING?
cg
Connecticut
Most of the brief P25 data calls I see are affiliations, registrations, etc which show up in the Event Log as background events. These last a second or two. If you don't have the background events turned on, it is in the menu or use the "b" shortcut while in the Event Log window.
I don't know if OTAP/OTAR being sent would show up as a data call, but the request might.
DaveNF2G
Latham, NY
Entries in italics are encrypted. If you want to hear the noise, then you need to enable encrypted call following from the menu.
billy2047
SYS REG RFSD
I have full following for encrypted voice call and that doesnt really change anything
billy2047
SYS REG RFSD
it's AVL/OTAR data and the controller is steering subscribers to the data channel. This is L/O in DSDFL and I'd like to have DSDFL follow/jump to the data channel if possible.
