schtefan
- Joined
- Jan 11, 2020
- Messages
- 9
Good afternoon. I can't make DSD+ 2.228 work in SDRSharp.
Downloaded version DSD + 2.228 moved to C:\dsdPlus, I press in SDRSharp "Start DSD" and it doesn't work.
I moved these files to a folder
All the files are in place, but the program DSD+ does not want to run, what should I do?
Is there anyway to program Conventional digital radio system in to dsd fastlane with sdr dongle and not having to sdr sharp or any other programs with dsd fastlane and is there way to make it scan
How do I do it
I got fmp.cc and r1 decoding one frequency at a time how do I use fmp24 and make the scan list
I'd like to make a suggestion. Look at all of the .TXT files in your folder where DSDPlus is installed. Read over those .TXT files in their entirety. You will actually learn a lot. If you don't see files with .TXT extensions, then you need to modify Windows Explorer (assuming you are using Windows) to show the extensions.
Files like Notes.txt, DSDPlus.txt, FMP.txt, FMPA.txt, Trunking.txt and "Phase II Notes.txt" all have information in them that should be read, and it is expected that people will read those text files.
Mike
I've never seen "Phase II Notes.txt" or "FMPA.txt" could you share copies? I've saved every update, don't recall those or which updates they would have came with Thanks..
