DSDPlus DSDPlus 2.256 with SDRPlay RSP1.
StaRipper
Hello friends,
Got DSDPlus 2.256 (Fastlane) ...
With my RTL_SDR v3 Dongle it's working fine and decoding P25 Phase II.
But, when i try to do it with my SDRPlay RSP1 i get the below message:
FMPP 1.13 -i1 -o20001
ERROR
Can't open SDRPlay device #1
SDRPlay device with serial number 1 is not present or is already in use
I see that FMPP displays that Serial # is 000000001 but i checked and it's not.
I set in FMPP.cfg serial number 0000000001 and tried the real serial number too. still i get the same error.
Does anyone has SDRPlay RSP1 working with DSDPlus ?
inside
RSP1 is no supported by FMPP.exe ! Leave this, or use virtual cable for run dsd and set manual settings.
inside
I am also have RSP1 dongle and maximum wat i can get the connect to DSD via Virtual cable.
Something ppls is reply about FMPP and Drivers api depend table.
FMPP v1.4 ask API 3.03
FMPP v1.6 ask API 3.04
FMPP v1.9 ask API 3.06
So.. I am need 3.04 Api , hope the help me , and you too if you can get.
All this info is already writeln on my post. So you can not made similar copy.
StaRipper
I found how to make SDRPlay RSP1 work with DSD+ Fastlane (v2.256).
DSDPlus -r1 -e -T -E -i20001
FMPP -rc -i1 -o20001 -f(frequency) -M3 -L5
inside
Hi, can you tell me with Api version you use ad FMPP.exe version ?
or better upload this two everywhere plz..
inside
FMPP Info CMD
FMPP 1.13
Usage:
FMPP [options] Normal operation
FMPP -h Show help
Options:
-i<num> SDRPlay device number (1-255) [-i1]
-o<num> Output audio device (1-255) [-o1]
-o<port> Output audio TCP port (256-65535)
-A<num> RSP2 antenna select (1-2) [-A1]
-N<num> Enable/disable RSP2 notch filters (0-1) [-N0]
-L<num> LNA gain (0-8) [-L8]
-M<num> IF gain (0-59) [-M30]
-T<num> Enable/disable RSP2 bias tee (0-1) [-T0]
-f<MHz> Initial tuned frequency [-f99.9]
-b<kHz> Initial filter bandwidth (4, 7.6, 9.5, 12.5, 22) [-b7]
-u<num> Enable/disable unlicensed spectrum display (0-1) [-u0]
-z<num> Show zoomed spectrum (0-1) [-z1]
-n<num> Select noise filter (0-2) [-n0]
-v<num> Set volume level (0-500) [-v100]
-s<num> Enable/disable scanner mode (0-1) [-s0]
-wsl<v>.<h> Spectrum window location [-wsl50.50]
-_<num> Minimize windows at startup; bitmapped
-rc Role is trunk control/rest channel monitor
-rv Role is trunk voice channel monitor
Active keys:
0-9 . Enter set frequency
[/] select step size
Cursor </> step frequency
Ctrl Csr </> step frequency by 250 Hz
U toggle unlicensed spectrum display mode
M toggle spectrum memory overlay
X reset spectrum memory
Z toggle spectrum zoom overlay
I select injection mode
b/B select bandpass filter
F select noise filter
Cursor ^/v adjust volume level
spacebar toggle muting
A toggle RSP2 antenna select
O toggle RSP2 notch filters
j/J adjust LNA gain
k/K adjust IF gain
R toggle raw I/Q and FM demod recording
S start scanner mode or exit hold mode
C start trunk control/rest channel following mode
V start trunk voice channel following mode
? list active keys
Esc exit scanner/CC/VC modes or exit program
Left click on spectrum: retune
