- Joined
- Oct 4, 2016
- Messages
- 64
Hi Group,
I am having issues attempting to run DSDPlus 2.390 Fast Lane with a single Airspy R2. I have updated the FMPA.cfg to include the serial number of the Airspy R2, per the instructions. After loading the 1R DSD batch file, I attempt to load the FMPA-CC batch file, but receive the following error shown below. I have confirmed in the .CFG file that the sampling rate is set at 2.5, which I have also pasted beneath the FMPA-CC error. I've tried FMPA 1p02 and FMPA 2p7, both produce the same error. Can anyone help point me in the right direction? Thank you!
C:\DSDPlus>FMPA -rc -i1 -o20001 -f935.0
FMPA rev 1.02t
Sampling rate must be 2.5 or 10
Error processing config file (FMPA.cfg)
FMPA.CFG setup (I have tried adding a prevailing 0 in the Airspy S/N number as well, as I read that might help, no joy either):
260868C82A2A6D9B ; Airspy and Airspy Mini serial number list
2.5 ; sampling rate (not used at this time)
1024 ; spectrum window width
64 ; FFT size (16k, 32k, 64k)
10 ; spectrum update rate in Hz
5000 -6250 7500 12500 15000 25000 100000 ; step size table; units = Hz; negate default
. ; DSD+ path
.\FMPA-FreqList.csv ; primary frequency list CSV path\filename
.\FMPA-FreqList2.csv ; auxiliary frequency list CSV path\filename
miles ; miles or kilometers
99.9 ; search distance
19.7163 -155.6241 ; search origin
FMPA rev 1.02t
. ; DSD+ path
