It runs fine under Windows 10x64 as is.
DSD+ and FMP24 are not "installed", they are command line programs that you just run from the command line. You do need to make sure you have the Zadig driver setup, that should be pretty easy.Thanks for the answer, maybe and the way we install it, should I use a particular procedure or driver?
