So, I'm trying to decode trunked radio, but I'm getting the error "audio input device open failed" when starting DSDplus in SDR#, so I could really use some help.
First of all, let me tell you about my setup.
I'm running Windows 10.
My speakers are plugged into the back of my pc, in the onboard soundcard.
I've installed the latest version of VB-Audio Virtual Cable.
My radio dongle is the NooElec NESDR XTR+
I'm running the latest version of SDR# (rev 1666).
I'm using the latest version of DSDPlus as well (1.101) with the DLL files installed, and I have set it up with SDR#.
I've followed several guides online, all saying the same, so it should work.
In my windows sound properties, I've changed VB-Audio to be the standard device under playback. In Recording I've done the same, but in the properties for the VB-Audio, I've checked "Listen to this device" and I've chosen my speakers (High Definition Audio) under "playback through this device" because if I select VB-Audio, I get no sound. I suspect that could be the problem, but I don't know.
Now, I've tried it on my laptop running windows 7 and it works fine.
Any suggestions on how to make it work?
