For anyone who needs to translate their DSD+ frequencies to Uniden LCNs on a Connect+ system here is how you can translate them (if you are having issues with the LCN finder on the current beta DMR firmware):
Example:
Example:
I tried searching the RR forums on how to do this earlier and didn't have much luck. (doesn't help when you can't search "LCN" "CON" "DMR" and "DSD" in the RR Forums because your keywords are too short).
Things are now tracking flawlessly!
- DSDPlus has two ch #s for each frequency pair (one for each frequency and slot)
- The first pair of frequencies will be LCN-1, Second Pair is LCN-2, etc
- Or simply take your even Ch #s form DSD+ and divide by two to get the corresponding LCN (you only need to enter each frequency once on your BCDx36HP)
Example:
Code:
454.1000/1 (DSD Ch-1 | Uniden LCN-1)
454.1000/2 (DSD Ch-2 | Uniden LCN-1)
454.2000/1 (DSD Ch-3 | Uniden LCN-2)
454.2000/2 (DSD Ch-4 | Uniden LCN-2)
454.3000/1 (DSD Ch-5 | Uniden LCN-3)
454.3000/2 (DSD Ch-6 | Uniden LCN-3)
Example:
Code:
454.275/1 (DSD CH-1 | Uniden LCN-1)
454.275/2 (DSD CH-2 | Uniden LCN-1)
454.250/1 (DSD CH-3 | Uniden LCN-2)
454.250/2 (DSD CH-4 | Uniden LCN-2)
454.025/1 (DSD CH-5 | Uniden LCN-3)
454.025/2 (DSD CH-6 | Uniden LCN-3)
