DSDPlus DSDPlus error
jerry01
Orange County, NY
Hey Folks,
I seem to be getting this error when I start the radio.bat file. Its was working fine then it started to get this error.
START FMP24 -rc -o20001 -P0 -f852.775
Any pointers would be appreciated,
Thanks,
rlmurray56
Puyallup, WA
That error occurs when your bandwidth setting does not match that of the system you are tuned to. Adjust with the "b" or shift "b" keys or add an entry to your batch file for the correct bandwidth setting.
cg
Connecticut
If you look at the help menu/file, you will see a value at the end of each line with brackets. That is the default startup setting unless you add a change to the batch file. So in this case, you will see [-b7]. If you want to it to be different when you start the program, you then want to add it to your batch file.
chris
