It's not going to generate audio unless FMP24 is connected to DSDPlus and in the DSDPlus Input menu you turn source audio monitoring on.
Ok, it defaults to 935 mhz. Irrelevant. Tune it to the control channel of some trunked system, any trunked system, in your area. You "tune" by focusing on the FMP24-CC waterfall window, and if you start typing a frequency you'll see it at the top of the window -- press enter to switch to that frequency.
And in DSDPlus make sure that in the Input menu you have it set to "Use Direct FMPx linking" and in the Control menu of DSDPlus you have it set to Combined CC/VC Monitor.
Forget about CSV files. They are irrelevant at this point.
