DSDPlus DSDPlus Fastlane single-dongle monitoring No audio
noamlivne
If it is a Phase1 system, which I think it is, you can also try Unitrunker http://www.unitrunker.com/download/. (I use the "old" version from 2017. There is an ongoing development of a new version but I cannot manage with it).
You can create two VCOs with one dongle: one would be a Signal role VCO and one would be a Voice role VCO.
Regardless, if it is a Phase1 system, also DSDPlus can listen to the talk channel. When you see that a talk channel is active, go to it and see what you can hear there. Of course this is not a good method to hunt for talk channels manually, but perhaps it would give you an idea what is going on there.
slicerwizard
Toronto, Ontario
You're dealing with a P25 system made by Aselsan Inc; it's not broadcasting all of the usual system/site identification messages. That's probably causing your issues.
WACN ID is 7D290
SysID is 001
RFSS / Site ID might be 6A.6A
Voice channels: 385.48125 386.28125 386.73125
Voice encryption might be in use. Try monitoring the voice channels. Tune FMP24 to a voice channel and enable squelch (press Q in FMP24) - then record in DSD+. The recording will be small - only active signals will be recorded (no static / dead air). Selecting Only Record During Sync in the DSD+ Input menu should also eliminate any dead air from the recording.
jocam29594
First of all, thank you very much. Unitrunker made me crazy.. fastlane is really very useful. IM keep going to achieve…
@sliYes, you are right, there is no information about the trunk system frequencies etc. . on any website and no one shares, so we are having trouble with the finding source.
Today first time heard uncoded voice. But maybe 5 seconds And then gone.. Unfortunalety there is no you mentioned voice channels.. moreover, I heard on sdrtrunk. So fastlane doesn’t help again.
As you see attched photo, tried op25 . Ofcourse I dont hear anything :) but give me some information. I dont know how I can use these numbers or codes..
If it is not private, I want to ask you. If I want to learn the information you wrote, especially wacn, Please could you check attached photo And maybe you can differ informations. In my picture wacn is unknown.
