thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,851
DSDPlus Fastlane updated - v2.245
Code:
DSD+ 2.245
Some stability improvements.
Fixed P25 neighbor reporting issue.
Added options for trunking site auto-loading/monitoring at DSD+ startup.
DSD+ can be configured to either load the trunking site that was being monitored
when DSD+ was shut down or to load a specific trunking site.
DSD+ must be running in CC Monitor mode or Combined CC/VC Monitor mode
and for non-P25 systems, site channel data has to be present in the DSDPlus.frequencies file.
An active TCP link to FMPA/FMPP/FMP24 is also required.
If site auto-loading fails, check channel records in DSDPlus.frequencies or DSDPlus.P25data.
Separate instances of DSD+ can be configured to auto-load different sites.
Use the -F<num> command line option to differentiate running DSD+ instances.
FMP24 2.65
FMPA 2.36
FMPP 1.13
Added support for the trunking site auto-load at DSD+ startup feature.
DSD+ 2.245 will not TCP link with earlier versions of FMPA/FMPP/FMP24.
Older versions of DSD+ will not TCP link with these updated copies of FMPA/FMPP/FMP24.
