DSDPlus Fastlane updated - v2.245
EricCottrell
Boston, Ma
I'm stuck on Ver 2.197, How do I update through the program?
Hello,
I thought it might be still possible to update from 2.197 manually, but the 2.205 and 2.212 are not available for me anymore. The parameters changed with version 2.228, and it appears versions older than this got deleted. You need to apply each update separately in order not to miss important new support files.
You need to contact DSDPlus support.
It is very important to download and archive the update zip files. I also keep a pristine version that I update and then zip the whole directory.
73 Eric
Kazzaw
South East QLD, Australia
On 2.246 (no thread yet)
I'm getting a couple of these coming through monitoring a certain network.
The frequency assigned to the channel doesn't have any registration or licensing and appears quiet when these messages come through.
Any idea what would be causing them?
Emerg OVCM Private call; Tgt=12189793 Src=16343402 Ch=25
u2brent
OAMPT
KRWDPAXKRS1
svfd455
somerville, tx
I have run into an issue while trying to start fmp24 as it tells me that libfftw3f-3.dll is missing but I’ve never seen this file. I also don’t know why it is making the pic sideways 84864
EarHoles
New Zealand
"Discarded WaveOut block"
I get this sometimes on a particular site,
Had a search and can't find a answer for what this means, anyone?
a417
If I had to guess, it's a malformed audio block that can't be sent to the audio / wave out device.
thewraith2008
Maybe this is a (audio) buffer overflow issue and DSD+ is discarding it to keep up with playback.
Maybe when a priority call is seen, DSD+ is discarding the previous calls audio from buffer.
Best person to ask is DSDPlus. They also may have a suggestion on how to overcome it or if it's OK just to ignore it.
Lindsay1
Calgary
Hi All
This is my first update and here is what is happing to the program
DSDplus 2.256
NOT saving synthesized audio to DSDplus.wav/.mp3
wav/mp3 file generation interval = 0 minutes
Enabling output audio AGC
Setting unvoiced speech quality to 3 waves per band
*** Invalid command Line parameter: '-dr0' ***
73s ve7lpg
a417
It is telling you the problem. You are passing -dr0 to dsdplus which is an invalid command line flag.
decoder options are -dv<NUM>,-dd<NUM>, and -ds<NUM>
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
That only ever happens to me when accessing a headless machine (running DSDPlus) remotely via RDP. Are you accessing the machine running DSDPlus from another computer using some sort of remote desktop software ?
