DSDPlus Fastlane updated - v2.245
Lindsay1
Calgary
Thanks for helping
I am still having problems getting it up and running
The program is saying I am missing a file. libfftw3f-3.dll is missing
It is not in the folder but were do I find it.
Thanks73s ve7lpg
a417
First page of text in Notes.txt said:
Setup
NOTE! YOU SHOULD ALWAYS BACK UP YOUR CURRENT DSD+ FOLDER BEFORE APPLYING A FAST LANE UPDATE!
YOU SHOULD ALSO PERIODICALLY BACK UP YOUR DSD+ DATA FILES
If you are a new Fast Lane member:
If you already have a DSD+ 1.101 folder set up, skip step 1.
1: If you do not have a DSD+ folder set up yet, go to DSDPlus.com and download
the most recent public version of DSD+ (currently 1.101); also download the
DLL package.
Unzip all of the files to a folder on your PC. We recommend using C:\DSDPlus.
2: You should also download this file:
ftp://ftp.fftw.org/pub/fftw/fftw-3.3.5-dll32.zip
Extract the libfftw3f-3.dll file from the zipfile
(it is the largest file in the zipfile) and copy it to your DSD+ folder.
3: Your Fast Lane update will contain all of the current Fast Lane files.
ALL of these files should be copied to your DSD+ 1.101 folder.
That folder will then be your DSD+ Fast Lane folder.
Lindsay1
Calgary
Thanks for the help
I have it up and running but with no sound will the new fast lane up date decode p25e.
It looks like it is there are no air messages coming up.
73s from ve7lpg
Denniskb103153
Ruther Glen
Code:
DSD+ 2.245
    Some stability improvements.
    Fixed P25 neighbor reporting issue.
    Added options for trunking site auto-loading/monitoring at DSD+ startup.
    DSD+ can be configured to either load the trunking site that was being monitored
    when DSD+ was shut down or to load a specific trunking site.
    DSD+ must be running in CC Monitor mode or Combined CC/VC Monitor mode
    and for non-P25 systems, site channel data has to be present in the DSDPlus.frequencies file.
    An active TCP link to FMPA/FMPP/FMP24 is also required.
    If site auto-loading fails, check channel records in DSDPlus.frequencies or DSDPlus.P25data.
    Separate instances of DSD+ can be configured to auto-load different sites.
    Use the -F<num> command line option to differentiate running DSD+ instances.
FMP24 2.65
FMPA 2.36
FMPP 1.13
    Added support for the trunking site auto-load at DSD+ startup feature.
    DSD+ 2.245 will not TCP link with earlier versions of FMPA/FMPP/FMP24.
    Older versions of DSD+ will not TCP link with these updated copies of FMPA/FMPP/FMP24.
I have never received the update for version 2.45 and it appears the website no longer exists. Can someone help?? Last version I got was 2.228.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
maxthered
Italy
2.245 and not 2.45
The last was : 2.275
