DSDPlus Fastlane updated - v2.245
thewraith2008
Code:
DSD+ 2.245
    Some stability improvements.
    Fixed P25 neighbor reporting issue.
    Added options for trunking site auto-loading/monitoring at DSD+ startup.
    DSD+ can be configured to either load the trunking site that was being monitored
    when DSD+ was shut down or to load a specific trunking site.
    DSD+ must be running in CC Monitor mode or Combined CC/VC Monitor mode
    and for non-P25 systems, site channel data has to be present in the DSDPlus.frequencies file.
    An active TCP link to FMPA/FMPP/FMP24 is also required.
    If site auto-loading fails, check channel records in DSDPlus.frequencies or DSDPlus.P25data.
    Separate instances of DSD+ can be configured to auto-load different sites.
    Use the -F<num> command line option to differentiate running DSD+ instances.
FMP24 2.65
FMPA 2.36
FMPP 1.13
    Added support for the trunking site auto-load at DSD+ startup feature.
    DSD+ 2.245 will not TCP link with earlier versions of FMPA/FMPP/FMP24.
    Older versions of DSD+ will not TCP link with these updated copies of FMPA/FMPP/FMP24.
thewraith2008
Anyone noticing problems with DMR TIII (MOT) CapMAX
I've always seen problems with this type but it looks like it's playing up more now.
When I select this site, DSDPlus can identify it as one of two different networkID, siteNumber values for what ever reason.
H2-51
H3-7.4
The H2-51 - This seems stable but I think the H3-7.4 is the correct one.
The H3-7.4 - This sees the 'Eventlog' window scroll continuously with "H3-7.4 neighbor: Site H3-xx; CC=xxxx" and the status bar fills up.
Moving off and on frequency in FMP24 (using left/right arrow keys) sees this randomly changing the identification of the site.
I normally don't see this scrolling of the 'neighbor' information issue.
relicwr
It's not loading my name and email like it did before. It just shows
DSD+ 2.245 / Fast Lane Release
It's still working fine, but that was immediately noticeable.
relicwr
It is possible that it's not reading the BIN file properly.
mariom76
Hello!
I'm trying to update but I get a DSD+ Update Download Failed. How can I resolve this?
Thank you
ArloG
Hmmm. Mine won't download
Updated DSDPlus.bin
DSD+ update is available
Downloading DSDPlus2p245.zip
'200 OK' not found
Update download failed
DRL-XM43
Durham Region
Yes I expect so since the email addy is no longer associated/shown in DSD+ startup.
I expect that is a concern.
I wish they would add an option to keep the siteloader window open until the user closes it.
Kazzaw
South East QLD, Australia
I've always seen this too. Can't confirm if its due to the newer update or not, the only couple of sites i monitor have always had this issue.
Re-adjusting the program role (Change from voice/control to just voice or control and then change back) seems to work, until moving to the next site.
relicwr
It's problably been pulled to resolve the registration not showing.
