DSDPlus.frequencies File
RonnieUSA
Rowan County,KY (Morehead)
I have been trying to get this to work, but can't seem to.
All of my frequencies are conventional, no digital trunked.
Here are 3 of a few I'm trying to add:
460.58750
453.72500
151.71500
Thank You for any help on this.
RonnieUSA
Here is a copy of what I'm trying to do:
; DSD+ frequency file
; line format:
; protocol, network ID, site number, OTA channel number, TX frequency, RX frequency, sort order
; use site number = 0 for network-wide definition
; use 0.0 for unknown frequencies
; use sort order = 0 to sort by OTA channel number
; protocols:
; D-Star
; IDAS
; NEXEDGE48
; NEXEDGE96
; dPMR
; DMR
; Cap+
; Con+
; P25
; ProVoice
NEXEDGE48, 0, 0, 460.587500, 1
NEXEDGE48, 0, 0, 453.72500, 2
NEXEDGE48, 0, 0, 151.71500, 3
LimaZulu
Well, I never had time to edit the file so can't be 100% sure if it's going to work but.... As far as I can see you are missing some parameters. You must set option for each parameter in order as given in the example: protocol, network ID, site number, OTA channel number, TX frequency, RX frequency, sort order. Counting from left to right you set only 5 parameters out of 7. Or in ohter words you set only first 5 parameters.
protocol=NEXEDGE48
network ID=0
site number=0
OTA channel number=460.587500
TX frequency=1
As you can see the last two lines contain wrong values. I'm not sure how to find the unknown values (some of them can be seen in even log window) but if we say that all uknown values can be set to 0 it sould look something like this
protocol=NEXEDGE48
network ID=0
site number=0
OTA channel number=0
TX frequency=460.587500 (if you are sure this is TX and not RX frequency)
RX frequency=460.587500 (just for example)
sort order=1
So your furst line is going to look something like this:
NEXEDGE48, 0, 0, 0, 460.587500, 460.587500, 1
Try it and let us know if this works :)
racingfan360
Ronnie - just to add, if you have more than one entry, you'll need to have some parameter that tells DSD+ how to distinguish between entries in the frequency file: I understand it's just a look-up table, nothing more.
So even if you add all 7 entries, you still need to be able to tell DSD+ how to distinguish between frequencies from a unique identifier (such as format, network ID, site, etc). So you need to say if it's site 1 = freq A, site 2 = freq B etc. At the minute it won't know which of the 3 freqs to display to you.
RonnieUSA
protocol=NEXEDGE48
network ID=0
site number=0
TX frequency=1
protocol=NEXEDGE48
network ID=0
site number=0
sort order=1
That worked to get them to load, but it's still not showing any thing in the channel window except source, and scrAlas.
I changed it to look like this:
NEXEDGE48, 1, 1, 1, 460.587500, 460.587500, 1
NEXEDGE48, 2, 2, 2, 453.72500, 453.72500, 2
NEXEDGE48, 3, 3, 3, 151.71500, 151.71500, 3
racingfan360
I should have clarified....if it's conventional Nexedge, there is no network ID, no site number, no OTA channel number for DSD+ to decode.
The freq file is just a look up table for DSD to match one or more of these parameters to a freq that you specify. DSD+ isn't finding any matches because there is nothing to match in your examples. It'll work on DMR conventional and/or Digital trunked because there are channel numbers, but not on NXDN conventional where there aren't.
RonnieUSA
Thank You, because that is gonna save me time trying to under stand why it's not working.
D
DaveNF2G
Guest
If you were monitoring a trunked system where these parameters would actually worked, I don't think the software would understand that the third channel belongs to a different system. Either that or it would interpret what you have as being frequencies belonging to three separate systems.
RonnieUSA
protocol=NEXEDGE48
network ID=0
site number=0
TX frequency=1
protocol=NEXEDGE48
network ID=0
site number=0
sort order=1
I got it to work on a Conventional DMR System.
DMR, 0, 0,1, 153.3975, 153.3975, 1
