DsdPlus log info
ronenp
Hi there
Where can i find a list of the DSDplus info and its interpretations ? such as CSBK and other type of data i see on the log screen ?
2) I know that inside the log there is a data that can be interprated as the radio manufacturer (in DMR repeater it can be known what is the repeater HYTERA Motorola etc) where exectly I see it and where can i find the various manufacturers code ?
Thanks For any Info
Regards
Ronen - 4Z4ZQ
Ronen Pinchooks (4Z4ZQ) WebSite
Forts
Ontario, Canada
To learn more about CSBK data you would need to pour thru the various DMR technical douments and whitepapers that are available. Depending on the system you are logging some of that data may be vendor proprietary however... meaning it's up to you to figure out what's what.
As far as manufacturer ID I thought DSD+ already showed this... I'm pretty sure DMRDecode did. The problem was that most vendors don't seem to set that bit....
