DSDPLUS new update how to use it?
shantanuk
Hello guys, 3 days before I paid for the fast lane program of DSD plus. They sent me updated files. I tried as per the Read Me file, but unable to upgrade properly with the old version and having some issues to start dsdplus (updated) with SDR#. Please check the screenshots. For "lame_enc.dll" I did a fresh download of DLL files from dsdplus.com and checked. but error remains the same. Please help me.dsd fastlane error.jpg
maus92
The OP
Sorta looks like your directory structure is messed up - can you provide some screenshots of your dsd folder?
cg
Connecticut
Sounds familiar, I think that issue has come up before with those who want to use SDR# instead of the FMPx that is made to run with DSDPlus. A search should turn up the answer in the forums.
chris
shantanuk
This is the folder where I put new update files in the older dsd folder. lame_enc.dll (fresh downloaded from dsd site yesterday )and suggested as per dsdplus devs libfftw3f-3.dll.
shantanuk
chris
Thank you Chris. I'm also finding a solution from various sources and trying hard to resolve it.
maus92
The OP
Yea, I didn't read your post carefully enough - didn't catch that you were using SDR#. Clearly the dll is not where the program expects it to be (or maybe a version error.)
shantanuk
I did all properly as per the given instruction from dsdplus read me file. can you share your configured dsdplus fast lane configured folder so I can try on it if possible?
k5357
bussey iowa 50044
The new lame_enc.dll must be slightly different than the old version because I had the same problem you describe. I thought I was copying the new copy to dsd+ folder several times but dsd still wouldn't function. I finally tried deleting lame_enc.dll from dsd folder before I pasted new copy, then dsd worked fine. I suspect that new file was not overwriting old file when it was not. Probably because of identical name files. However I did not get a pop up message to overwrite file like win10 usally does, I do remember that
slicerwizard
Toronto, Ontario
"Required file not found in current working folder"
You're not running DSD+ in your DSD+ folder, right?
You're running DSD+ in the SDR# folder, because you're using an SDR# DSD+ plugin that runs DSD+ in the SDR# folder, right?
Where does DSD+ say it's running?
shantanuk
"Required file not found in the current working folder"
You're running DSD+ in the SDR# folder because you're using an SDR# DSD+ plugin that runs DSD+ in the SDR# folder, right?
Yes, I'm running DSD+ from the DSD+ folder.
NO, the DSD+ folder is on 2 locations 1st on my D: drive which is the public version, and 2nd on C: drive (C:\dsdplus) which is upgraded (new files in the old version). Both folder directory is not in sdr# at all. Yeah, but the plugin file is in the sdr# folder to run dsd+.
Didn't see any error that specifically saying this question. (The upgraded version is in c:\dsdplus)
Note: I was very excited to work with the dsd+ fast lane program. Trying hard for 4 days, not there is nothing happens positively to increase my hopes to work hard again and again to resolve this issue. I'm losing my interest.
cg
Connecticut
Out of curiosity, why are you wasting so much time trying to get DSDPlus working with SDR#? Are you able to get it working from FMPx?
chris
air-scan
This is what should be in your DSDPlus FL folder it shouldn't be mixed in with SDR# at all. I feel like you're making it harder than it has to be. Keep it simple!
Directory of C:\SDR-Apps\DSDPlus
10/01/2020 01:45 PM 2,519,449 1R-DSDPlus.event
09/25/2020 01:23 AM 7,313 1R-DSDPlus.srt
05/07/2020 06:59 PM 3,218 1R-log.txt
09/23/2020 10:04 AM 46 1R.bat
09/23/2020 10:04 AM 51 1Ra.bat
06/13/2016 10:40 AM 88,064 airspy.dll
09/10/2020 09:49 AM 836 CC-DSDPlus.event
09/23/2020 10:04 AM 42 CC.bat
09/10/2020 09:49 AM 0 CC.log
12/25/2015 04:29 AM 5,711 Changes.txt
10/01/2020 01:45 PM 352 DSDPlus.bin
09/24/2020 09:40 AM 605,724 DSDPlus.exe
12/25/2019 05:05 AM 2,635 DSDPlus.frequencies
10/01/2020 01:45 PM 46,268 DSDPlus.groups
12/25/2019 04:32 AM 499 DSDPlus.networks
09/27/2020 05:03 AM 8,221 DSDPlus.P25data
10/01/2020 01:45 PM 179,796 DSDPlus.radios
12/25/2019 04:31 AM 2,722 DSDPlus.siteLoader
05/02/2020 04:52 PM 705 DSDPlus.sites
10/01/2020 01:31 PM 20,158 DSDPlus.txt
12/09/2015 12:39 AM 31 FMP-CC.bat
05/30/2020 04:24 AM 5,944,820 FMP-FreqList.csv
09/08/2020 04:41 PM 303 FMP-Map.cfg
10/01/2020 01:45 PM 48,320 FMP-Map.dat
05/14/2015 12:06 PM 57,856 FMP-Map.EXE
12/09/2015 12:39 AM 27 FMP-VC.bat
05/14/2015 05:45 PM 726 FMP.cfg
12/08/2015 07:54 PM 128,028 FMP.EXE
12/25/2015 01:15 AM 16,073 FMP.txt
09/23/2020 10:00 AM 37 FMP24-CC.bat
09/23/2020 10:00 AM 29 FMP24-VC.bat
09/10/2020 10:02 AM 727 FMP24.cfg
10/01/2020 01:31 PM 658 FMP24.dat
09/23/2020 09:43 AM 196,636 FMP24.exe
09/25/2020 01:50 AM 2,768 fmp24.txt
09/23/2020 10:00 AM 30 FMPA-CC.bat
09/23/2020 10:00 AM 22 FMPA-VC.bat
12/09/2015 12:39 AM 717 FMPA.cfg
09/23/2020 09:43 AM 173,596 FMPA.exe
12/23/2015 05:49 PM 3,127 FMPA.txt
09/23/2020 10:00 AM 30 FMPP-CC.bat
09/23/2020 10:00 AM 22 FMPP-VC.bat
09/23/2020 09:42 AM 174,620 FMPP.exe
05/03/2015 06:44 PM 491,008 lame_enc.dll
07/30/2016 04:08 PM 2,391,615 libfftw3f-3.dll
12/06/2014 06:09 AM 95,744 libusb-1.0.dll
05/05/2015 12:03 AM 336 LRRP.cfg
12/08/2015 07:54 PM 58,880 LRRP.EXE
03/21/2017 05:45 AM 773,968 msvcr100.dll
07/23/2017 01:58 AM 653,120 msvcr90.dll
12/08/2015 01:32 PM 343,040 msvcrt.dll
09/23/2020 01:10 PM 97,583 Notes.txt
12/06/2014 06:09 AM 61,952 pthreadVCE2.dll
05/03/2015 06:44 PM 46,080 rtlsdr.dll
05/03/2015 06:44 PM 46,080 rtlsdr_FC0012.dll
04/14/2020 07:13 AM 28,160 sdrplay_api.dll
12/25/2015 02:49 AM 5,113 Trunking.txt
09/23/2020 10:04 AM 42 VC.bat
ignore all the dates and numbers only note the files. The reason it looks like that is because I used the command dir >list.txt command while in the command window. this is all you need. FMPx + DSDPlus linking is the way.
TheMatcus
I found that I was using DSD+ FastLane and it was giving me this error. Downloading the public version of DSD+ and not installing FastLane made it work in SDR#
Forts
Mentor
Ontario, Canada
Errors like this have been brought up soooo many times, and the answer is always the same. Stop with SDR# for now. Get DSDPlus running, as it was intended, with FMP24 or FMPA. Once that's working, then introduce SDR# back into the equation if need be. At least at that point you'll have a known working configuration to deal with. Don't forget that the latest fastlane version also has the option to download all required files and dlls.
