rolypolyman
I've noticed that my copy of DSDPlus is not properly writing output WAV files. It appears to be completely ignoring the -I interval value that I've set. I've tried 30 minutes and 15 minutes with no effect. It just keeps piling on a single WAV file that grows endlessly.
The command I use that calls DSDPlus is as follows (copied and pasted):
dsdplus -T -v0 -i20002 -o4 -ds62 -dd35 -dv19 -I15 -OM soundfiles\dsd.wav -Pwav
Currently the directory looks like this:
The WAV files simply keep piling up in a single WAV file. The only reason you see multiple files here was from me stopping and restarting DSDPlus.
Here's a status message so far. I've been running it for about 6 hours, and you can see here it is ignoring -I15 and letting it pile up into a massive file:
Note that THIS DOES NOT CONCERN the per-call WAVs, which are something different and are called with -P. Those work perfect.
I don't see any command to check the program version. This is not the Fastlane version though. I'm a Fastlane supporter but I'm running regular DSDPlus on this frequency until I get time to change it over.
Is there anything obvious I'm doing wrong?
Code:
09/23/2021 12:12 PM <DIR> .
09/23/2021 12:12 PM <DIR> ..
09/12/2021 07:25 PM 647 dsd.2021-09-12@1906.srt
09/12/2021 07:25 PM 112,044 dsd.2021-09-12@1906.wav
09/18/2021 04:38 PM 1,615,708 dsd.2021-09-12@1940.srt
09/18/2021 04:38 PM 264,560,044 dsd.2021-09-12@1940.wav
09/23/2021 06:11 AM 1,818,462 dsd.2021-09-18@1646.srt
09/23/2021 06:11 AM 296,608,044 dsd.2021-09-18@1646.wav
09/23/2021 06:35 AM 661 dsd.2021-09-23@0621.srt
09/23/2021 06:35 AM 112,044 dsd.2021-09-23@0621.wav
09/23/2021 12:05 PM 146,754 dsd.2021-09-23@0635.srt
09/23/2021 12:05 PM 24,192,044 dsd.2021-09-23@0635.wav
09/23/2021 12:09 PM 0 dsd.2021-09-23@1209.srt
09/23/2021 12:09 PM 0 dsd.2021-09-23@1209.wav
09/23/2021 12:12 PM 0 t.txt
13 File(s) 589,166,452 bytes
Code:
2021.09.23 12:05:34 1512.0 seconds (24,192,000 bytes) of synthesized audio written to 'soundfiles\dsd.2021-09-23@0635.wav'
