DSDPlus DSDPlus problem after computer overheat
cg
Connecticut
I am trying to help a friend of mine get his DSDPlus working properly again.
We are both very familiar with the various DSDPlus programs and operations.
His Dell XPS 9100 shut down due to overheating. We replaced the paste on the CPU/heat sink and the machine is running fine again. Everything seems to be working properly except for the operation of DSDPlus and FMPx together.
Right now the audio is completely unreadable in all digital modes. WX or Air traffic work fine through FMPA/DSDPlus using raw source mode 1 option
- FMP24 and FMPA react the same, bad audio using either
- All DSDPlus and FMPx files replaced from backups (including supplied .dll files)
- DSDPlus works from a remote computer running FMPA to a local copy of DSDPlus
- FMPA works sending CC/Voice traffic to a remote copy of DSDPlus
- SDRTrunk works with audio fine
- Sound card plays audio files youtube audio, etc fine
- changed the ports used between DSDPlus and FMPx
Looking for any ideas to get the program working again.
chris
a417
No unusual errors when running local to local, just garbled audio?
and are logged recordings garbled as well, or just local audio?
cg
Connecticut
Thanks for the reply,
recordings duplicate the live audio (poor).
Also, signal is excellent, my laptop running his SDR devices and antenna has very good, readable audio.
chris
a417
Reset the win10 TCP/IP stack?
netsh int ip reset from administrator command prompt, iirc.
check to see if windows firewall is interfering with ports?
