Dsdplus proper command for audio gain control
LD723
Does anyone know the correct command code for the sort of auto audio gain control for the fastlane version? I was using random command lines and the command -g-1 enabled the audio gain control thing but the weird part is that I can use any number with that command but if I remove the number for example that "1" it will not work so what is the exact correct command for it? And does the number matter? And I'm not talking about the manual gain control.
thewraith2008
From the documentation:
Must be a positive number. Your value "-g-1" is -1
Code:
-g<num>     Output audio gain (0.001-999; 0=auto) [-g0]
LD723
Code:
Yes but when I use it in that combination "-g-1" in the command prompt side of dsdplus it said something like audio gain control enabled but if I used "-g1" it would say something like audio gain set to 1
thewraith2008
Using "-g-1" is the same as using "g0" or Auto. Console = "Enabling output audio AGC"
Using "-g1" is "Setting output audio gain to 1.000"
In both cases, gain is on.
Don't use "-g-1" that's not the range of the option. [0.001-999]
LD723
Ah ok I understand it now lol when I used this option it changed my audio quality better for dmr and worse for p25 lol.
