DSDPlus.siteloader file not found
AB9NN
Beulah, MI
I am receiving the following error messages and am unsure how to proceed to diagnose the errors:
DSDPlus.siteloader file not found in working folder
Required data files not found in working folder
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Addressed ad nauseum in the forums. Use that Search feature in the forums to find it.
DSDPlus 2.197 added the DSDPlus.siteloader file and SiteLoader window, per notes.txt.
I'm attaching my DSDPlus.siteloader file. It is modified. You will have to edit it if you want to use the siteloader feature. You MUST rename this file from DSDPlus.siteLoader.txt to DSDPLus.siteLoader.
m
  • DSDPlus.siteLoader.txt
mtindor
OH/WV DB Admin
Shame DSD+ could not just create that file if missing, as stated. Would save a lot on electrons!
I understand that sentiment. But I also like that sometimes we are all forced to use our brain once in a while. The brain is a terrible thing to waste. And, we don't all want to be like the Scarecrow in Wizard of Oz, singing "if I only had a brain."
Mike
slicerwizard
Toronto, Ontario
Yeah, let's go back to the days when DSD+ would randomly delete your data because something prevented it from properly reading a data file. Actually, let's not.
There's no good reason for that file to be missing. I don't want my data put at risk because someone can't follow simple instructions.
TheButcher
DSD+ asks... "Dang no "xyz" file. would you like me to create one ? Yes / No?
Would save on time... Not trying to create lazy minds archetypal...
"There's no good reason for that file to be missing. I don't want my data put at risk because someone can't follow simple instructions."
That would be a good question to ask ?
"Yeah, let's go back to the days when DSD+ would randomly delete your data because something prevented it from properly reading a data file. Actually, let's not. "
Would you like DSD+ do nuke your file or not? y/n ?
Back in the day, I was able to rip videos out of games by creating a zero byte file. Good times, good times indeed (1.8 or 2.5gb hdds !). This was before the days of CD burners and in fact cheap blank cds ! But, I digress... Not everyone can figure this stuff out. Hence the Internet / forums. Dang those reading this will learn something, which is the point of Mr. mtindor
