DSDPlus DSDPlus Virus???
NC4AB
Wallburg, NC
Windows Defender just flagged DSDPlus.exe (version 2p448) for having a Win32/Phonzy.B!ml Trojan, just curious if anyone else had this show up and is it real or a false positive?
Multiple virus scans have said all files in the zip folder are fine, as long as you downloaded it through the DSD program you'll be fine, if you got it anywhere else that's on you.
NC4AB
Wallburg, NC
Direct download through DSD+ FastLane, Windows Defender keeps flagging it as a Trojan. Running a Malwarebytes scan on it right now.
Andy
NC4AB
Wallburg, NC
Weird - Defender flags 2p448 as a Trojan but not 2p444. A scan with Malwarebytes says both files are fine.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
On my Windows Defender, this is the threat I received with my 2.448 download.
Trojan:Win32/Sabsik.FL.A!ml Defender did its thing and quarantined it before my eyes.
It was this file in particular:
DSDPlus2p448\FMP24.exe . It had flagged that file as failing, so I downloaded the base file.
GTR8000
NY/NJ Database Guy
BEE00
Interestingly, it's only flagging the original 2.448 executable as a threat, not the replacement 2.448 executable that was quietly released 24 hours later without any notification or version bump.
I've never had issues with DSD+ Fast Lane going back to 2017 or whenever it was first released, however since the author is "unknown" (to most, at least), I can certainly understand why some would be cautious. Running software from a largely unknown coder on one's primary PC does take a little bit of faith in the community being fairly large with no real issues ever being reported to date.
frazpo
SW Mo
:unsure: Makes you wonder.
LimaZulu
Sometumes, when you make a mistake in your code, which is not unusual and happens to everyone, you often create so called "access violation" which is basically trying to access memory that's not yours. Or in other words, memory that is out of the scope of your application. Such behavior is sometimes categorized as some kind of threat by anti virus softwares which is to be expected.
Not that I am trying to justify someone, I just want to give another point of view as to why you may want to release a new version as quickly as possible skipping all kind of notifications, version changes and so on.
jets1961
I had false positives way back a few years ago, forget version number. But it was just that a false positive.
