DSDPlus DSDPlus working fine on one computer, cannot get it running on new computer... stumped
xPotential
KF0̷MLK 2IS1987 WSGQ866
Minnesota
so on my old laptoip I have a single dongle setup using DSDPlus and FMPA and it has been running fine for years now..
on my new laptop I copied the folder from the old one and cannot get it to work
it says "SDR device #1 is in use" and "RTL SDR device #2 not found"
then it tells me that single receiver mode requires FMPA link
im using the exact same folder that works on the old laptop
this is what my batch file looks like
START "" "FMPA.EXE" -rc -i2 -o00000001 -P0.0 -f851.8875 -_3
TIMEOUT 3
START "" "DSDPlus.EXE" -T -E -_15 -- -H3 -i00000001 -g0 -o1 -OM NUL -I720 -PBmp3 -M16 -r1 -m0 -f1 -F1
TIMEOUT 3
again, that works perfectly with a single dongle on the old laptop.
what the heck am i missing?
ive tried using the latest public version, the latest fast lane, switching drivers, etc
SDR# works
haaaaaaaaaaaalp!!!!!!!!
EDIT::
i realize that FMPA is set to used device #2 ( -i2 )
this is how i have it working on my old laptop with only one device connected
if i change it to to device #1 on the new laptop, it runs into that device being in use, which it is not
there is nothing running using that device. i can reboot the computer and just run my batch file and it tells me device 1 is in use
xPotential
Minnesota
The -i2 parameter on FMPA.exe is telling program to use AirSpy device #2.
yet it works perfectly on the old laptop with only one device
and if i change it to -i1 then it runs into device #1 being in use, which it is not. and thats with closing everything, rebooting, unplugging and plugging back in, etc
xPotential
Minnesota
Possible the new laptop not seeing dongle properly.. What does device manager show for the Airspy?
It's an rtl-sdr, I've tried my old v3 and a v4. The drivers are installed correctly and it works with sdr#. It just isn't working with fmpa, or I should say, it is showing up as being in use.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
You say are you using a dongle and then are using FMPA. When one says dongle on here, it is generally thought of a standard RTL dongle. The Airspy (mini), although in "dongle" form, isn't considered an RTL dongle. It's not a Realtek device.
So are you using an actual RTL dongle? Or an Airspy/Airspy mini?
If a dongle, use FMP24, not FMP
And, when in doubt, use what you are supposed to use (FMPA-CC.bat / 1R.bat for Airspys, and FMP24-CC.bat / 1R.bat for RTL dongles)
And make sure you haven't put any of that into a windows protected folder. Always best to either put it in c:\dsdplus or in c:\users\<username>\desktop\dsdplus.
xPotential
Minnesota
I've tried with my RTL-SDR Blog V3 and V4, which work fine on the other laptop running FMPA. I run it from a folder on the C drive just like on the other laptop where it works just fine. It's showing that the device is in use. No matter what I do or what batch file I run.
mtindor
FMP24 PRO USER
No. FMPA is for Airspys. If you have a V3 or V4 dongle, you have to use FMP24
It doesn't matter what you say or think, you are wrong about this. FMPA will never work with a V3/V4 dongle, just like FMP24 will never work with an Airspy.
Whether you are using public or FL, please just try the defaults (which are always recommended)
FMP24-CC.bat and 1R.bat
No funky batch jazz. Verify that it works. If it doesn't work at this point, you need to re-run Zadig because the drivers were not installed properly.
Mike
xPotential
Minnesota
Mike
Well maybe it's been renamed for some reason or another. The fact is that the batch file I posted originally, with the executables in the folder, works fine with my V3 on my other laptop and has for 6 years.
In fact it's running right now since I couldn't get it to work on this new laptop. Using the same exact batch file and executable files, with a V3. And yet on the new laptop, with the exact same set of files, it opens just fine but says my device is in use.
The drivers have been installed and replaced and Uninstalled and reinstalled 75 times at this point.
The only difference is that for whatever reason on the old laptop in the batch file needs to point to device #2 even though only one device is connected.
I do see that the FMPA in the folder from the old laptop is in fact FMP24 that was apparently renamed by me for whatever reason 6 years ago. So I will try using the latest version of everything and correct it to fmp24. But this does not explain why the same working folder that runs fine on one machine does not on the new machine. That same folder has been copied to my desktop and another laptop in the past without issue.
Nor does it explain why it claims the device is in use.
mtindor
FMP24 PRO USER
I’m glad that you Admitted to having rename the file at some point. Because under no circumstance will the proper FMPA work with a dongle or FMP24 with an airspy
If you reboot and do nothing other than to try and run FMP24-cc.bat and it tells you that a device is in use, then it’s a driver issue.
You really need to go through a nuke anything that looks like an RTL driver or RTL device from your device manager. Then go back in, and run Zadig, and I do that with admin privileges.
mtindor
FMP24 PRO USER
And by all means, do make sure you are running the latest DLL‘s and support files. If you’re running fast lane or the latest public release, you can fire up dsdplus and I think in the miscellaneous menu, you can make sure you’ve got the latest version and the latest DLL and support files
And if you’re running a V4 dongle, I think there is a specific DLL for that although I can’t remember and I’m not in front of a computer right now
xPotential
Minnesota
well now we're maybe getting somewhere. it still shows device 1 in use, but the sdr is showing up as device #2.
buuuuuuut... it is giving me "rtlsdr_V4.dll is missing" even though rtlsdr_V4.dll is in fact in the folder because it ships with DSDPlusFull these days.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
xPotential
Minnesota
welp, after fixing the v4.dll issue..
i finally got it up and running.
thank you for pointing me in the right directions
