Old4rd said:BARELY a slight improvement in Genesee's CQPSK reception.
Just curious where you ran it... I spent about half of my time in Swartz Creek along 69, then got off 69 near the Red Cross building and it was a very noticeable improvement.
code6 said:Updated to 1.3 upgrade on both the 96 and 2096 and reception was improved on both,
but now on both radios digital transmissions drop out randamly and at differant times for each radio when they are on side by side, even if they are on the same frequency,one radio will drop out and the other one continues to decode digital transmissions.
This happens while monitering LAPD which is a very active agency,the frequent drop outs are very annoying.Also noticed this on the Orange County CA countywide TRS when on
digital signals,however those signals are improved when not dropping out.
mpg0515 said:This is the same thing that is happening to me on the CO DTRS. Really annoying I will be going back to 1.2.
Going back to 1.2 worked ok for me. You'll need to go through each step, to activate the upgrade button.code6 said:I've been trying to figure out how to go back to 1.2 with no success.
I found a way to go to 1.1 but would like to go back 1.2 instead.
There is 1.2 on the RS web site but I can't get it to work.
code6 said:been trying to revert to factory setting useing 0,pgm,clear,enter.does not work.
DaveIN said:Did you try fmon's method?
fmon: "Going back to 1.2 worked ok for me. You'll need to go through each step, to activate the upgrade button."
code6 said:Yes can not get 1.2 to work either
Rob, do you mean pressing the 3 key when the welcome screen comes up to see what version is in for the DSP? If so good point because that is the way that I checked mine after doing the upgrade.rdale said:Are you doing the key sequence when the welcome screen is up?
Dave,DaveIN said:From the DSP 1.2 Update instructions (not provided in the 1.3 version):
"Reverting to the factory DSP firmware version
If for any reason you decide that you would like to revert to the original factory DSP version (F1.1), you
may do so by pressing 0, then PGM, then CLEAR, then ENTER during the “Welcome” screen. Note
that this will permanently remove the upgrade from the DSP flash memory. You can reload the upgrade
as many times as you like using the PRO96U12.EXE upgrade utility."
I added this to the PRO-96/2096; Wiki/DSP Upgrade section.
0.pgm,enter is the correct procedure, however, you need to use the 1.2 exe program to revert back, unless you are reverting back from the first U1.2 upgrade from F1.1 which was in the early Pro-96.code6 said:been trying to revert to factory setting useing 0,pgm,clear,enter.does not work.
fmon said:Dave,
The pdf provided is the original instructions for upgrading from DSP-APP F1.1 to U1.2, and may still be required if one has never changed to U1.2 in the early Pro-96 scanners. Otherwise, I don't know why Radio Shack provided the pdf again.
EDIT: I don't think the Pro-96 can be reverted to F1.1 once U 1.3 has been installed. Of course, the 2096 never had a F1.1.
