DSP `Upgrade' Clearing Sequence Error
Halfpint
Slightly NE of the People's Republic of Firestone
OK... I'll admit that it sounds a bit rediculous that I *seem* to be the only one who has had this problem. However... The *published* `clear' code for the DSP upgrade appears to be *WRONG* for the PRO-2096 & PRO-96s around here! The *published* `code' [Even in the November issue of Monitoring Times!] reads:
While the "WELCOME" message is still on the screen, press 0, then PGM, then CLEAR, then ENTER.
BUZZZTTTT...! *WRONG*!
The *only* way I can get the PRO-2096 & PRO-96s around here to `clear' the DSP `upgrade' is to do the following:
While the "Welcome" message is on the screen, press 0, then press CLEAR, then press ENTER.
If *I* press 0, press PGM, then press CLEAR, like the `*published*' / `*publicized*' sequence I get thrown right out to `normal' operation. If I press 0, press PGM, then press ENTER I get sent to the "DSP LOAD PC/IF Port Flash Mem"screen. (Could it be that it is a `typo' and the majority of the people who `publicize' it haven't actually used it, have done it the way I discovered yet figure that they experienced FFS [Fat, or Fumble, Finger Syndrome] and they had really done it the `typo' way without realizing it, *or* since the Ghods at RS have `spoken' it is `the way' it is to be done no matter what? {AARRRGGGGHHHHH!!!!!!} I mainly say this because not only have I seen it here on TRR but I have seen it many other places and finally seeing it in the November 2006 issue of Monitoring Times at the end of an article, actually the third `subject' in the "Scanning Report", that purports to explain what the `upgrade?' is `supposed?' to do I finally `reached the end of my rope?' and, at the very least, want to mention that this appears to be a mistake. )
I've just `puttered along' all this time with the DSP version 1.3 in my scanners and never bothered clearing the `upgrade?' figuring that at the very least I would give it a chance to `prove' itself to be useful and would `attack' the `problem' when it came time to remove it or replace it with something else that might `come down the pike'. (Or, hopefully, maybe not even have to be bothered by it because RS finally offered an `upgrade' that would take care of whatever this one was `supposed' to do along with making 700MHz DTRS trunking available on the 2096 /96 scanners ala' the version 1.4 CPU `upgrade'.) However... After all this time I've come to the conclusion that despite what everyone seems to be claiming it really isn't `worth a hoot' on the Colorado DTRS 99% of the time and in that remaining 1% the difference is just *barely* noticable. In fact, at least with the PRO-2096 & 96s available (3 PRO-2096s and 2 PRO-96s that are `mine' and a `set', 1 PRO-2096 and 1 PRO-96, that is my `daughter's'.) listening to the various agencies / departments I mainly listen to, I have noticed that quite a few transmissions (While I never actually set out and put pencil to paper and made `marks in column `A' or `marks in column b' all the time, `column A' would be `populated' with at least 2 - 2½ more `marks' than would `column B'! ) are a lot better on the 2096 / 96s that haven't had the `upgrade'. (If I had the time, *space*, and money I *really* would like to have some of the fancy test equipment I've caught mention of. But, since I don't and only have what test equipment I use for repairing and restoring Hi-Fi / Stereo `gear', I've had to depend upon my equipment and my senses. [You should have heard the complaints I got when I set up the test equipment! I `wiped out' almost a third of the available seating, along with a fair amount of floor space, in our living room and caused a whole heck of a lot of H&D over who got to sit where. 'Course SWMBO and I still had *our* seating. {GRIN!} It was the 2 children who were the cause. (Those of you who *may* have a pair, daughter about 13 and son about 9, may understand?]) After enduring the H&D for several weeks, though SWMBO claims it was more like months, I finally packed up the equipment and went back to using `calibrated senses'.) Today I finally decided that even *if* there was an announcement that RS was going to offer the aforementioned `upgrade' I was going to clear out the DSP V.1.3 `upgrade?' and set about doing so. (On all of the scanners I had installed the `upgrade', 2 PRO-2096s and 2 PRO-96s, around here the only steps that actually cleared it were the ones I outlined above *not* the `published' / `publicized' ones.)
Just an `Olde Fart's' 2¢ worth. {WAN GRIN!}
rdale
Lansing, MI
FYI - while your information may be valuable, it is nearly impossible to read your post due to all the punctuation marks that fly off your keyboard. You might want to invest in a new one to help with your problem...
iMONITOR
Silent Key
S.E. Michigan
Here is a screen print of the instructions from the DSP update software:
