DTMF Mic HMN1032B vs HMN1052B
joncleve
Western NC
Can someone tell me the difference between these two mics? They both look identical and will probably will work with both the Maratrac and Spectra. I've searched online and can't find a definitive answer.
cmdrwill
So Cali
I know there were two different Mics for Spectras, ect. The difference is the length of the cord and placement of the strain relief clip. The A5 and A7 mic has a longer section between the connector and strain relief clip. The A9 type has a shorter length between the mic plug and strain relief clip as the clip attaches on the back of the head.
So that may be the difference..
joncleve
Western NC
I'm sorry, I meant the 1053. The 1053 looks identical to the 1032, DTMF and the same connector.
KG4INW
Midlothian, VA
I believe the 1053 is for the Astro Spectra so there's probably some internal differences but I'll try to check later.
KG4INW
Midlothian, VA
OK, fairly strange. I've been looking through some old parts catalogs and they conflict each other. One says the 1053 is only for the old analog Spectra whereas a different catalog lists it as being compatible with the Astro Spectra. I haven't found mention of the 1032 yet but I know they exist!
KG4INW
Midlothian, VA
Then why did M make note that several of the mics are not compatible with the AS? There's also that thread on the other forums listing modifications for the 1052 to convert it to the 1080.
