Hi all,
There have been various posts about trying to extend the range of the DTR-650 by the use of an external antenna. I have a few observations to share
and a few questions to share with others. I'll start with the question 1:
Question 1: Have you used the new model (DTR600 or DTR700) DTR radios and achieved greater range with an external antenna? If yes, how much more range did you obtain?
Question 2: Have you used the older models (e.g. DTR-650) with an external antenna and achieved greater range? If yes how much more.
Observation 1: I have a tower mounted commercial vertical (cometelco) rated 5db or so, connected to a commercially made run of about 70 feet of LMR400 with N connector, to what appears to be a well made adapter to SMA. This setup greatly extended the range of a 900mhz MTS 2000 (HT) to another HT while I drove about. Radio to radio in my drive which can be described as flat land, urban/suburban mix, but with ALOT of trees compared to many places. HT to HT reception was 1 mile or le ss. HT to tower mounted antenna about 2.5 miles. Again, this is what I have come to expect her on upper UHF frequencies; you get much LESS than line of sight in my area due to foliage attenuation, unless you are above the canopy. As an aside, this same 900mhz antenna hooked up to a 1090mhz filtered dongle, receives ADSB out to 250 miles, so I have reasonable confidence it is working OK.
Observation 2: Hooked a DTR-650 to the same setup, with same coax and adapters, with the tower mounted 900mhz antenna (about 30 feet up), and driving around, I get much less range, then I get HT to HT with built in antennas (the full sized ones that are 7 inches or so). I have tried various adapters and various DTR-650 radios, and none work well on the tower mounted antenna. Some adapters seem to not work at all, given reception dies around the block, some give me about .7 miles of range. This suggests that the antenna jack on the radio is a little picky or different somehow.
Observation 3:One day I took at DTR650, and used the belt clip holster to put it on the tower directly at about 30 feet. Now I got the same roughly 2.5 mile coverage as the MTS2000 achieved with the tower mounted antenna. Ahh, now this is working.
Conclusions/summary: 1. There is something different about the antenna jack, at least I suspect there is, such that not all adapters work. 2. The radios perform poorly with a large, external antenna. 3. Given how they work, its very difficult to test the radios. 4. I wonder if the radios become "deaf" and/or "overloaded" when hooked to a large antenna, in a fashion similar to the HAM grade HT's I used back in the late 1990s. 5. One of these days, I may try this again, as a field operation in some remote area, free from cell towers, and random 900mhz ISM stuff.
Anyone make this work?
Regards
Regards
