Dual Band/Dual Head just clicks when I try to turn on.
dhalbasch
Antioch, California
I had a dual band/single head tk790/tk890 for years without a problem. It then started to not turn on once in a while, most of the time it would turn on. Last month it just stopped turning on at all, it would just make a noise like a relay closing. I've been wanting to upgrade to a duel head setup, which I did this weekend. All parts of the dual head setup are brand new out of the box, the control cables I also replaced with new. Still same problem.
I've confirmed good power to both decks.
Both radios have the CalFire firmware if it makes a difference.
Nothing was done to the radios prior to this issue.
Any ideas?
Thanks for reading,
Dennis
dhalbasch
Antioch, California
I ment to mention that it never was hooked up in the first place. So the answer is no, but it's worked for years the way it is.
Any ideas?
Well, not sure what vintage the radio is, but these have been out of production for a while.
Intermittent issues like that sort of suggest a component starting to fail. Your best bet would be to sit down with the radio and a service manual and start going through it until you find the offender.
The only relay in it is for the horn relay circuit. There's no relays in the power circuit.
For simplification, I'd put it back into it's original configuration (single head) and start working on it. Trying to trouble shoot it with a new head attached is just going to add to the confusion.
dhalbasch
Antioch, California
Other than turning on and off, it probably has been years since I programed it, however, I'll figure out what pin to hook power to and give it a try. Can't hurt. The only problem is I'm evacuated due to the Zogg fire, no idea when I can get back in. (or if anything will be there when I do get back).
Dennis
ramal121
Lots and lots of watts
Calif Whine Country
Grabbing at straws here, but whenever I get a weird problem on a remoted X90 the first thing I do is pop off the covers and make sure the control cables are seated firmly. Run into this every so often. Easy enough to check. Older units are more prone to this as the little white connector doesn't have the positive "click" the new units do when inserting.
