I actually use a handheld on 6m and get into local repeaters with it just fine with a 1m long antenna on the radio. Its simplex radio to radio that doesn't work so well and MURS or a 4w GMRS hand held works a whole lot better.
I know, that's why I suggested the Crossband feature........
Uniden, President Electronics are you Listening? Say goodbye to CB radio as your primary consumer communications device, and say "HELLO" to the new and improved MURS radio service... Off the grid communications for the 21st Century!!!
U.S. 49 MHz VHF-Lo *MURS Band Plan
TX/RX Mode of Operation FM (10 Watts rms)
Channel / Frequency / Bandwidth / Recommended Use
1A. 49.6750 (20.00 kHz) Interstate Highway Channel – Long Range
2A. 49.6950 (20.00 kHz) Off Road Vehicle (4WD) channel --- Long Range
3A. 49.7150 (20.00 kHz) Long Range Talk Around Channel
4A. 49.7350 (20.00 kHz) Long Range Talk Around Channel
5A. 49.7550 (20.00 kHz) Long Range Talk Around Channel
6A. 49.7750 (20.00 kHz) Long Range Talk Around Channel
7A. 49.7950 (20.00 kHz) Long Range Talk Around Channel
8A. 49.8150 (20.00 kHz) Long Range Talk Around Channel
9A.
49.8400 (20.00 kHz) Emergency / Travel Assistance ONLY
10A. 49.8650 (20.00 kHz) Long Range Talk Around Channel
11A. 49.8950 (20.00 kHz) Long Range Talk Around Channel
12A. 49.9150 (20.00 kHz) Long Range Talk Around Channel
13A. 49.9350 (20.00 kHz) Long Range Talk Around Channel
14A. 49.9550 (20.00 kHz) Long Range Talk Around Channel
15A. 49.9750 (20.00 kHz) Long Range Talk Around Channel
*Multi Use Radio Service (see Title 47, Chapter I, Subchapter D, Part 95 Subpart J)
U.S. 150 MHz VHF-Hi *MURS Band Plan
TX/RX Mode of Operation FM (2 Watts rms)
1B. 151.820 MHz (11.25 kHz) Short Range Talk Around Channel
2B. 151.880 MHz (11.25 kHz) Short Range Talk Around Channel
3B. 151.940 MHz (11.25 kHz) Truck / Cargo Terminals --- Calling Channel
4B. 154.570 MHz (20.00 kHz) Off Road Vehicle (4WD) channel --- Short Range
5B. 154.600 MHz (20.00 kHz) Interstate Highway Channel – Short Range
(see Title 47, Chapter I, Subchapter D, Part 95 Subpart J) Will need to be modified to include the Low Band frequencies and power level...
