Motoflightmedic
I have had this dual band setup for a while. about a year ago i realized the Low band deck had gone deaf. So i grabbed another low band radio and did the mods that are required for this type of setup for the second radio. I then started having some pl decoding issues. so after some research i figured out that both radios need to have the same firmware in them. Today i Had a couple of different low band and UHF decks and installed the newest firmware off of kenwoods dealers website in them, did the typical bench tests for tx and rx checks. both radios were well within spec. I put everything together and dump the programming in and now when i power up this system i get a beep, pause, beep, pause. just a continuous loop.
My first question is, how do you tell what firmware checksum is installed in the radio? I guess i should have done this first but i can backtrack if i need to.
second question is what is the beep pause loop trying to tell me?
