First, to address the inevitable:
- “You can only do this with a W3 head”: Just because that’s the only official support doesn’t mean it won’t work otherwise. For example, even though you’re supposed to only give an Astro Spectra the control head listed in its model number, I’ve found in some cases you can just throw on the wrong control head and it works just fine.
- “Why not just use an APX7500/8500?” I don’t want to. And there’s some things that I can do with 2 XTL5000s that can’t be done with as easily with an APX. Also I like these kinds of experiments.
Now onto the main course: has anyone tried a dual brick setup with a non-W3 head and did it work? Or any indications that it would work, or know how to make it work? I am guessing with some certainty that it would probably work with zero or little modification needed with other W-series heads, but what about an O5 head? Also, could I still have VRS functionality with 2 bricks? My plan for the wiring is: primary brick goes to control head through GCAI cable. Accessory port goes through DB25 splitter to VRS and secondary brick. My bricks have the multi radio flashcode. What the heck does a codeplug for a dual radio setup look like? How does zone/channel assignment work? How integrated are the codeplugs between the 2 bricks?
Just figured I’d ask some questions before stuffing yet another radio into my car. I will probably try it regardless and report back on if it works or not and anything interesting.
