And they will send and receive one 2 diff. Ferqs. at the same time ? Iasus call's it a 4-way.. I will post spec's here in a bit.
IASUS Dual Comm Radio
Price: $199.00
Shipping Weight: 1.90 lbs
Please select a valid combination of attributes.
An option must be selected for Voltage.
Quantity in Basket: None
The IASUS Dual Comm Radio is a unique 4-way UHF radio communication device designed to optimize use of IASUS NT3 Throat Mic Systems. It is the world’s first commercial portable 2-way radio that is able to operate on two different 1/2 duplex systems, effectively rendering it a 4-way radio. The IASUS Dual Comm Radio can simultaneously monitor and communicate with two independent groups of 2-way radio frequencies – perfect for coordinating multiple independent communication groups.
Professional four-way radio communication for airsoft/scenario paintball, outdoor recreation, work sites, and emergency and law enforcement operations.
The IASUS Dual Comm is not your average two-way professional UHF radio. The Dual Comm is capable of operating on two different ½ duplex systems, effectively rendering it a four-way radio. This unique system allows you to monitor and communicate with two independent groups of two-way frequencies, making the Dual Comm the ideal system for coordinating multiple groups. Built to U.S. military standards for shock, vibration, rain, and dust with a weatherproof die-cast aluminum chassis, the IASUS Dual Comm has the power and the durability to perform under the harshest conditions.
Dual Com Standby
• 5 km range
• Rechargeable lithium battery
• Water Resistant
• 4W Output Power
• 50 CTCSS
• 104DCS Normal/Inverted Selectable
• Backlit key pad
• 128 programmable groups
• Built-in FM radio receiver
• Scrambler
neral
Frequency range 136-174MHz 350-390MHz, or 400-470MHZ (only one set of frequency per radio)
Working Temperate -20°C~ +50°C
Operating Voltage DC 7.2V
Operate Mode Simplex or Semi-duplex
Dimension 59mm (W) * 119mm (H) * 34mm (D)
Weight 220g including battery
Transmitter
Frequency stability ±2.5ppm
Output power ≤5W
Max Frequency Deviation ≤5KHz
Audio Distortion ≤5%
Modulation Character +3dB~-3dB
Adjacent Channel Power ≥65dB
Spurious Radiation ≤7.5µW
Occupied bandwidth ≤16KHz
Receiver
RF Sensitivity <0.20µV
Audio distortion ≤5%
Audio response +2dB~-10dB
Adjacent channel selectivity ≥60 dB
Intermodulation rejection ≥60 dB
Spurious response ≥60 dB
Blocking ≥85dB
