Dual Radio XPR
Muxlow
Super Secret
Middlesex County
Just curious of this is a thing.. or could make a cable to do this
I have a UHF and VHF XPR4550. Is it possible to have 1 control head operate both radios in a remote setup?
I have my Macom Orion set up like that. 1 control head controlling 2 radios with a button to switch between each radio.
Audio from both radios come thru the speaker and what not.
If this possible to do on the XPR 4550 radios? 2 radios 1 control head?
KG4INW
Midlothian, VA
There's nothing official from Motorola to do that, I've never heard of anyone being able to do it (not even claiming to) and I don't think it would be very easy to any way. Would be nice though.
Muxlow
Super Secret
Middlesex County
I figured as much when i googled it and nothing really at all came up
*Sigh*
Would be super to have the radios mounted in the trunk and not have to worry about running to control heads and all that annoyance. Things to ask santa for i guess
KG4INW
Midlothian, VA
Yeah, especially with most modern vehicles and the lack of mounting space they have.
You got that right!. We need more remote head capable radios / scanners, space is at a premium on new cars these days..
Muxlow
Super Secret
Middlesex County
Even the Harros M7300 no longer supports dual radio setups like the Orions did.
Can have 2 control heads on ONE radio.. but not ONE control head on 2 radios. That helps everyone out OH so much :)
a417
Ditch the XPR and go to a Kenwood x90 series. Single & Dual head for dual deck options. If you're not committed to Trbo, then look into it.
They're rock solid, brick ****house radios.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Too bad the TK-x90 are limited to 160ch across BOTH radios... very limiting.
ni1f
xpr4550
does any one know how to read the pins on the back of the 4550 is it from left to right or is it right to left ??
I'm making an aux. cable for it to work a PA spkr.
KG4INW
Midlothian, VA
If you have the accessory connector (necessary to hookup such a cable), several pins are labeled so you don't have to guess. You will have to count to determine all of the others but it's not bad. Just remember that all the even pins are on one side.
ni1f
xpr4550
thanks for reply.........I'm actually going to do it shorty.I had a senior moment earlier then relised the connector only goes in one way.In others words yu can put it in upside down it won't let you.
thanks again.
