I'm posting this to the railfan section because the setup I am installing is geared almost exclusively for railfan monitoring. All other considerations are secondary. That, and I'd like to see if I can't filter out some of the inevitable off-topic arguments that end up running most radio-related threads into the ground.
I'm installing two IC-2720H rigs and two Larsen 5/8 NMO mount whips in my '03 Chevy S-10 pickup. It's an extended cab, so there's a pretty generous area to work with. I've got the headliner and trim out of my truck, have the routing figured out, the hole saw and the whips are on order.
My big question is, what's the best arrangement of two antennas. Side by side? Front to back? How much "clear area" does each antenna need before they start interfering with each other? Both whips will be cut for the railroad band.
Eventually, I will likely install a third rig for strictly 2-meter use, with a dedicated antenna mounted on the rear of the truck bed. But in the meantime, should the need to transmit arise, am I going to damage the non-transmitting rig by having two antennas on the truck roof? This is why I'm not using a single antenna and a splitter. (I also realize that a 161 tuned antenna isn't ideal for 2-meter, but I've used my old mag-mount Larsen 5/8 to get in to the occasional repeater on low power and it's been acceptable.)
I'd like to get thoughts and feedback on the best approach for this install, but hopefully keep it on the practical side.
Thanks in advance ...
