Dulles MWAA Re-banding
SkyPager
Arnold, MD
My sources tell me that the MWAA system at Dulles is being re-banded Monday - Wednesday of this week. Subtract 15 MHz. Work appears to be ocurring overnight. No other info available.
freqhopping
Lo Co VA/ FM19
Running UniTrunker on it right now, this is what I'm getting.
LCN 35 851.8875
LCN 61 852.5375
LCN 466 862.6625
LCN 476 862.9125
LCN 487 863.1875
LCN 657 Alt cc
LCN 658 Alt cc
LCN 688 868.2125 control channel
LCN 829 Alt cc
The radio tech TG is pretty active. But my Pro-106 is only partially receiving comms. It seems like when they're on 862.6625 I get nothing but static.
j2brown
I uploaded a new configuration using what is currently in the database to the RR.com owned PSR-500, providing the MWAA public safety feed, and it appears to stop on channels but I get no audio from the scanner. I'm hopeful that I did something stupid like mute something, and I'll discover it as soon as I publish this post. However, in the event that something else is awry, does someone have a PSR-500/PRO-106 configuration that I can try?
jeff
sdg
freqhopping
Lo Co VA/ FM19
You need to have this table programmed.
j2brown
That looks like what I have, except I didn't have the 800 MHz "Rebanded" selected for the "Standard" band plans. I've fixed that. It's still stopping on channels, but there's no audio. A quick switch to WX shows me that the scanner can make noise and I can hear it through RR.com. Any other thoughts?
jeff
sdg
j2brown
So the setting reverts to <select>, but maybe that's expected.
jeff
sdg
j2brown
Tried changing Trunking Tables to Custom from Default. That was the issue. Operator error. Easy to fix, once you fix the operator.
Thanks for the help.
jeff
sdg
freqhopping
Lo Co VA/ FM19
MWAA has an application in with the FCC for some more frequencies.
851.0125
851.5125
852.0125
852.5125
853.0125
Also noticing that today an alternate control channel is in use.
kg4icg
Crazy Trucking Mechanic
Woodbridge, Va
851.0125
851.5125
852.0125
852.5125
853.0125
Hate to be the bearer of bad news but you are nearly a year later.
Sent from my SPH-L710 using Tapatalk 2
