Duplicate Frequencies
cpohlad
Midlothian, VA
I was trying to update my list of frequencies for a P25 system I had imported. I went ahead and deleted the one previous and figured I would import again from RR. I did this but didn't do it how I wanted and now when I got to import it tells me it can't duplicate frequencies. It doesn't show up under the P25 systems so is there a way to clear this from PPS?
You might need to delete the profile and start over. You don't explain what you did or where you are getting the message so it is difficult to diagnose.
cpohlad
Midlothian, VA
So far I've deleted all the trunk IDs and the zone information for that system. When I go into the RadioReference import to import the frequencies for the system it tells me there are duplicate frequencies already but I don't know where to go at this point to find them because they don't show up under the P25 trunking information.
cpohlad
Midlothian, VA
Thank you for helping me track it down. The issue was, STARS has labeled some of their mobile sites with the same DEC and so once I removed those it was all good.
