Duplicate talkgroups
PJH
Looking at DTRS database, the following talkgroups are showing as duplicate entries. Please advise which is accurate....
Durango:
Water
or
Parks
Lincoln County, which one is LE 1, or which may be LE2 or something else...?
4951efDLincolnCo LE 1Law Enforcement 1 Law Dispatch
562232DLincolnCo LE 1Law Enforcement 1
abqscan
DataBase Administrator
Moderator
AOA
I've been able to monitor 562 from the metro area. I haven't figured out if 495 was abandoned or why they switched.
Spitfire8520
Might be slightly less clueless! =)
Colorado
Lincoln County moved from 495 to the brand new talkgroup 562 this past June for some unknown reason. Unfortunately I do not think anyone is in a position to figure out what happened to 495. I guess it should be marked as Deprecated until someone can figure out if it is truly gone or just repurposed.
rbuxton
Hesperus, CO
Durango:
Water
or
Parks
4951efDLincolnCo LE 1Law Enforcement 1Law Dispatch
So are trying to determine TG usage for Durango or Lincoln County?
PJH
Both: apparently the Durango talkgroup number didn’t carry over. If you look at Durango in the dtrs section, the the talkgroup ID is duplicated for both functions
rbuxton
Hesperus, CO
8404 = Durango Water, 8408 = Durango Parks/Recreation
