Durham Region Supplies
DRL-XM43
Durham Region
I am new to the area and wondered If anyone knows a local supplier for RG58 coax and SMA connectors, I have google searched but no luck... Thanks.
mciupa
DB Administrator
Moderator
I have used satellite cable coax ( good for the higher bands), which is reasonably priced nowadays as a substitute. They should have that in stock.
gary123
I have used the satellite cable too although it is 75 ohms it still performs quite satisfactory for shortish runs (75 ft or less) and RX only.
DRL-XM43
Durham Region
These guys have pretty much everything you need Nutech Electronics they have a place in Hamilton and I just happened to be there today so I am all set,
Thanks for the suggestions.
Doug.
