Hi, l’ve just bought an AOR DV1 and l’m just playing around with it.
l’ve notice compared to my AOR 3000A especially in AM on the air bands the 3000A picks up signals that the DV1 cannot hear.
Is there a setting some where, where the sensitivity can be adjusted, and when scanning in AM what’s the best bandwidth to set the receiver too?
The AOR Manual says any signal attenuation on the AR-DV1 is 'automatic'. It has no manual adjustment. 'Attenuator function is always activated automatically and no attenuator indicator is displayed on the LCD screen'.
Page 25 (4-3) explains the RF Gain function, but in tests that should not be engaged, using the 'fast' AGC level for the frequencies you mention. For Aircraft AM transmissions an IFBW of '8' is appropriate.
One person had a similar problem but that proved to be a dirty BNC connector (in his case the socket on the Radio, cured with Switch Cleaner).
It would be interesting to know
exactly how your experiment was conducted?
Without a stable Signal generator the only way of removing most if not all unwanted variables would be to run both Receivers at exactly the same time, each monitoring the identical specific Frequency with the Squelch 'OFF' in VFO Mode, and using just ONE aerial connected to each Receiver via a Splitter. Then swapping the leads to each Radio over and repeating the tests, to remove any possible disparity in the Cables / BNC plugs from the Splitter.
IFBW should also be the same. Using a 'moving' Aircraft signal the comparison MUST be observed / monitored at exactly the same time naturally.
Minor differences in 'S' readings between any two Receivers (even the same Model) can always be expected.
