Hello
@air-scan, I saw your other post about buying the 40 feet (12.2 meters) of 18 AWG for USD $6.00 (€4.98) at Walmart. Post #8 in
that thread by
@ka3jjz mentioned the relationship of wire length to received frequency.
Just as an FYI to show you that your 10 foot antenna is not too far off, the formula for one leg of a dipole antenna (which is what you essentially have) is:
234 / f (MHz) = Quarter-Wave (feet)
Using the received frequency of this thread, 14.257 MHz, we can calculate the correct antenna length as:
234 / f (MHz) = 234/14.257 = 16.413 feet = 16 feet 5 inches
Rearranging the formula, we can calculate what frequency your antenna is theoretically best suited for:
234 / Quarter-Wave (feet) = f (MHz) = 234/10 = 23.4 MHz
Sooooooo... just a little math there as an introduction to radio theory. You have probably heard of dipole antennas which is your antenna with another leg running in the opposite direction of the same length. The formula for the overall length of a dipole is obviously then:
468 / f (MHz) = Half-Wave Dipole (feet)
The only other comment I would make is this. Most HF signals that you will be listening to are horizontally polarized. In contrast, VHF and UHF signals that you listen to on a scanner are vertically polarized. That is why scanner antennas point up to the sky in order to better "catch" the vertically polarized radio waves. If a scanner antenna were in the horizontal plane, the received signal would not be as strong due to the polarization mismatch.
In your case for your shortwave receiver, ideally the antenna out your window should be horizontal. In your other post that I referred to earlier,
@mmckenna mentioned they were using speaker wire for their shortwave/AM antenna. It is probably more horizontal than vertical, I would think. I could be wrong. As you have seen, it will still receive,
just not as good. To overcome the polarization mismatch issue when I lived in a third floor apartment, I had my antenna running between the two furthest windows of my apartment. I had a friend hand out one window and I hung out a window at the other end and slingshot a tennis ball with fishing line tied through it to my friend with a baseball glove. That way, my HF antenna was horizontal with respect to the ground. I used 26 gauge enamel coated magnet wire that I had laying around. It was so thin nobody could even see it but it worked like a champ. Probably not the best price in the world be here it is from Amazon:
I hope you find this information at least a little interesting. You seem like a person that likes radios and likes to experiment. If you buy that one pound spool from Amazon of 26 gauge enamel coated magnet wire, you should have enough for years of experimentation. It doesn't say how many feet you get but it had got to be quite a few.
Cheers and 73 (best wishes in ham lingo), Dave K4EET
P.S.: Let me know if you have any questions...
P.S.S.: Happy DX hunting on the shortwave bands!
