DX394 Quick MOD
Here is a quick and actually good mod i did for the radio shack dx-394 VFO knob
I used 4 hex nuts one for each slot inside the vfo and some hot glue. The made a huge difference in tuning. Now it does not feel so toyish.
Go easy with the hot glue. If you make a mess just use a lighter and go over it a couple of times (not to much or you will melt the shaft hole)
here is the info on the nuts i used.
Item # 6212, 1/4-20 Hex Nut on The Hillman Group
Total cost was $1.19
af0h
Park Hills, MO
Simple and Effective. The weighted dial does make it feel more like a 'Real Radio' - I agree. I did the same thing with mine a few years ago using 4 small fishing Sinkers. Same effect, just had them onhand already.
Its a really easy mod that anyone can do and i wanted to share it with others. Thank you for the reply and your input.
Mike
