Dyess AFB Trunked gone silent
nd5y
Wichita Falls, TX
Maybe they joined one of the DoD nationwide systems or changed control channels to one that isn't in the database.
Search 380-420 MHz in 12.5 kHz steps and see if you find any new control channels.
If you don't find any control channels there then search 138-150.8 and 162-174 MHz in 12.5 kHz steps and see if they moved to VHF.
bravo14
Polk County FL
Not sure what you are asking.
380.0625 is listed in the database as the secondary control channel.
there is a control channel signal on that frequency currently
Ed
Asking if the System ID and Site is the same. The past few years AFB been moving to a larger system as the two links I put up.
nd5y
Wichita Falls, TX
I'll figure it out next time there is a band opening in that direction or next time I go down there. I don't think anybody there has DSD, Unitrunker or Pro96Com.
nd5y
Wichita Falls, TX
Home Patrol I and a 436
I think those have a trunked system analyze mode that shows the WACN, System ID, Site Number, NAC and probably other stuff when parked on the control channel. I have never used a HP so I can't tell you how to use it.
bravo14
Polk County FL
Okay I can give you some steps to show info
This is on the 436
1 only run the AFB System
2 click the menu button on side of radio
3 scroll to Analye
4 choose system status
5 just hit enter (even though its blank)
6 if you got 1 system select just hit enter
7 select site hit enter
8 you'll see some info
Write down the info and when done you can hit F+System to go back to normal scan
fasteddy64
Gulfport, MS
This is on the 436
3 scroll to Analye
Everything is blank
System ID
site id
s q and a lines
nothing
fasteddy64
Gulfport, MS
Okay that's odd. When scanning the system do you hear any audio? If not they might be doing some testing possible.
I get nothing when scanning.
If I search the range of the frequencies of the system I get a control channel on 380.0625, digital transmissions on several of the other frequencies but I am unable to hear the transmissions.
bravo14
Polk County FL
Give this a try
Make a new p25 system and put in the freq in and try analyze see what you get.
